Online: harderometry, Humbug, Merv
Where to puy Electric Plugs
  • the_mongrel
    the_mongrel
     Hi Lads,
    So I changed out my bars on the weekend - all good - but in the process I broke the clip on one of the multi plug that controls the indicators etc and the bastard has come undone, so now I need to pull the tank.  I could just tape it up but thought... if they are easily had, I would just replace them.
    Anyone know where I can get these - and what they are actually called?
    They are these ones...
    thin cable tie between the wires around both plugs
    I've repaired plugs that pull apart easily before, by using Electrical shrink wrap.
    Buy some that you can just slip over the plugs, grab a hair drier, heat up the shrink wrap, wrap shrinks and no more plug coming undone.
    Perthogs suggestion does work too, but I find the shrink wraps, more robust.
  • Rick1310
    Rick1310
     You could also go to JayCar as they have a lot of plugs some that are semilar to Harley style as well.
  • the_mongrel
    the_mongrel
    Thanks lads,
    I have taped it up for now, but I need to do a better job. The problem is getting to the bastard! I can get the tank back a bit, but ideally it needs to come off. :(
    I will get some new plugs and the next empty tank ( i just filled it) I will rip it off and do fix it!
  • Ando
    Ando
    Mongrel when ya take your tank off next do what I did
    Get some more fuel hose a T peice and a plug make a drain line for next time, I just cable tire the drain line from the T to the frame down tube
  • Colstah
    Colstah
    Ando! Great idea!!
  • Will67
    Will67
    cant see properly if its a 6 or eight pin here is a eight pin, its a bit differant but will do the job.
    http://www.ebay.com.au/itm/DEUTSCH-BLACK-8-PIN-DT-CONNECTOR-KIT-EASY-CRIMP-TERMINALS-HARLEY-CAT-AUTO-/221143030724?pt=AU_Car_Parts_Accessories&hash=item337d26dbc4&_uhb=1#ht_4550wt_1163
  • Will67
    Will67
     another type
    http://www.ebay.com.au/itm/Deutsch-DT-series-8-pin-connector-kit-waterproof-green-strip-grey-/130681973959?pt=AU_Car_Parts_Accessories&hash=item1e6d40acc7&_uhb=1
  • Will67
    Will67
  • the_mongrel
    the_mongrel
    ANDO - Where do you put the T-Piece? Mine has the quick release fuel connector.
    WILL - They look good, but I would have to change both, as they have different clips to hold it. But thanks... I am getting closer. :)
  • the_mongrel
    the_mongrel
    Ok - Found what they are. They are a Molex MX150. Just need to find them local - Should be easy enough!
    http://www.ebay.com.au/itm/1-Harley-8X-BLACK-MALE-OEM-Molex-MX150-connector-terminals-switch-wiring-07-up-/260875596557?pt=Motorcycles_Parts_Accessories&hash=item3cbd65b30d&_uhb=1#ht_3793wt_1044
  • Ando
    Ando
    Not the fuel line to the injectors but the crossover line under the front of the tank, stops fuel pissing everywhere when draining the tank for removal.
  • the_mongrel
    the_mongrel
    Ahhh! Clever!! I will look into that for sure!
    To save me looking it up - do know the size spec on the line?
    Mongrel
  • sic-puppy
    sic-puppy
    good god ....u want everything dont you lol
    its about time to see a go-pro on this fat my boy now you have your apes
    and thanks for the idea of the plumbing chrome cable
