Changing engine number WA
  • Dingo
    Dingo
    I have changed the motor to 120r, does anyone know if it's just a matter of filling out the form to change the engine number on registration or does the bike have to go over pits?
  • Ando
    Ando
    Dingo I just changed my engine number when I fitted my 120R pretty simple, from memory it cost zero dollars
  • Dingo
    Dingo
    Thanks ando, I was hoping that was the case.
  • the_mongrel
    the_mongrel
    Just thinking about that boys... Don't the newer bikes have the engine number stamped on the frame?
    no mongrel thats the vin/frame number sometimes almost the same as the engine number
  • the_mongrel
    the_mongrel
    Hmmm I will check mine out when I get home, but I am sure both numbers on the engine and frame are identical.
  • the_mongrel
    the_mongrel
    So I have just checked and the number on the sticker is stamped into the frame and etched into the engine!! I told ya they all matched!! :)
