103 ci engine upgrade??
  • FAT-BELLY
    FAT-BELLY
    Has anyone got wind of when the standard 103 stroker kits will be available?
    Got a "13" fxdf and not real happy with its output considering the 96 with a
    stage 4 kit is rounding me up like I'm on a scooter...
    even any cam, head and intake etc that's a suitable hp upgrade.
  • mickle
    mickle
    Welcome to the forums Belly.
  • FAT-BELLY
    FAT-BELLY
    Cheers mickle!
  • Will67
    Will67
     welcome
  • Ando
    Ando
    Plenty of stuff can be done to a 103 without changing pistons and barrels and without porting to get ya + 100/100
  • FAT-BELLY
    FAT-BELLY
    Thanks Baloffski! Had a good read..
    Ando what are we talking about? 20- 25+ rwhp I know I need a decent tune after putting stage 1 gear on her, what's ur suggestions?
  • HogBag
    HogBag
    ? A stage 4 96 cube bike is rounding you up. The stg4 kits have 113 cube motors not 96. I would buy the new s&s 124 engine with 12 months warranty and blow that pesky little 113 into the weeds. There the same price as the 120r race engine and look like there pumping more power from the box with 135/135 but time will tell as people start buying and getting them tuned.
  • FAT-BELLY
    FAT-BELLY
    Hog bag I have a 2013 103ci with stage 1 etc,
    My old fella has a 2009 96ci with a stage 4 (103) kit he is smoking me stupid... All I want is up near 110-115 and ill be happy. not looking to pull out my brand new motor (unless ur keen to buy it)
    What's a 113?
    Cheers belly
  • HogBag
    HogBag
    The 100/100 is easy to get but 110 to 115 is a major rebuild requiring crank welding with good stage 3 heads ect. Its cheaper to buy a 120r or the new S&S 124 star engine. The 113 is the SE stg4 kit 117/117 for around the same price as the above engines after you sell your stock 103 engine. I'm not interested in your motor been there and done that with a stocker. Thanks for the offer anyway.
  • FAT-BELLY
    FAT-BELLY
    Up in central Nsw but ill travel anywhere depending on reputation. Looking for low to mid more pick up n go..
    Anyone got good feedback on the 113 kit??
    Cheers belly
  • Rick1310
    Rick1310
     Fatbelly
    My mate just had his 08 FLHX done with a stage 3 & it made an improvement I took it for a ride & it was a big difference to my 07 FLHX. A couple of weeks ago it was writen off he now has a 2012 Road Glide which is a bit of a slug compared to his streety. I have just had my top end done on mine I went for the Stage 3 & then also the Pro CNC heads, which I could of just had a stage 4 done but I didn't want to change my throttle body as I didn,t want to change my air filter & since I have had it done everytime I ride it I have a smile on my face which will wear off one day. But it puts me in a good mood every morning going to work @ 5am
