Online: baldy1450, Hilly
oil problem
  • Finny
    Finny
    18 years ago
    Hi guys just wondering if anyone can help me. I have a 95 road king that keeps blowing oil out of the air cleaner area, ive changed rings did base gaskets rebuilt carb and put a k&n air filter(as my machanic sugested) but i feel im getting done over.
  • shadowhand
    shadowhand
    18 years ago
    My advice is get a Arlen Ness Big Sucker air cleaner as the backing plate bolts practically close the breather holes on the engine (normally oil comes out of here). I got one and mine doesn't leak anymore. Just make sure you have a large brake pedal like the stock Road King pedal as the filter can restrict leg movement on softails.
    Is the oil leaking from the filter? Start it up and watch.
  • Finny
    Finny
    18 years ago
    Thnx for replying back ill try the big ass kickin filter
    and i didnt fill it to the top by the dipstick
