hid,s
  • sic-puppy
    sic-puppy
     has anyone fitted hid lighting to there bikes[ones with light bars] like the deluxe , glides etc. i dont mean just whack a hid globe in it and go , i mean with the correct projectors that give a correct light cut off. theres a guy on another forum that does it  4x4,s,trucks and what not and the performance of these lights is nothing less than brillant.
    i,m thinking of doing the deluxe, and was after some opinions
    just to bring a few up to date
    i ordered my gear for my hid  on the weekend and it turned up today, well packed
    now to sit down and make it happen
    here are some pics of whats in the box
    ian
  • rider
    rider
    Sounds interesting sp, but for performance and "cut-off", or precise direction of light, I always thought that it was the reflector that determined the spread and patern.
    Most of us that have tried HID have gone to LED's for what we beleive is a superior light.
    HID's are cheap enough, so it will be interesting to see what the Correct projectors are all about and what they add to the cost as compared to the not so cheap LED's.
  • sic-puppy
    sic-puppy
    rider, the guy i,m referring to is on ebay as well as other forums ...hails out of newcastle i believe. from looking at the results of what hes done , i,m hoping to set up the light bar on a deluxe. but i,ll wait till i see what can de done first.
    can anyone tell me if the lights are all sealed beams,and what sizes are the lights on the deluxe
    thanks
  • rider
    rider
    OEM on the passing lights are 4 inch semi sealed beams with 12 volt 35 watt halogen globes, usually.
    You gotta link to the guy that does the conversion ?
