CARB ISSUES
  • Emperor15
    Emperor15
     Hi Guys,
    A quick question. What causes the air fuel ratio to change on my bike? It was running fine last week and is now missing and back firing. I assume this means the ratio is off? It's an 85 Evo.
    Thanks
  • Emperor15
    Emperor15
     I'll have to get it looked at, I'm next to clueless mechanically. Do ignition problems cause the same sort of backfires and splutters? Thanks
    clean fuel tank &  jets as well as carb bowl  1st  & put in a new set of spark plugs @ least
  • Emperor15
    Emperor15
    Thanks guys, I'll check the battery cables tonight.
  • Colstah
    Colstah
    Tell you what makes my '94 evo miss and backfire is having the enrichener out for too long when starting up. Too long is more than 15 seconds or so.....
  • houli
    houli
    90%  of carb problems are electrical.
  • Colstah
    Colstah
    Not sure what you're getting at badcooky. Stock carb, stock evo, plugs foul up if I have the enrichener on for too long, so it's obviously too rich with the enrichener out.
    Otherwise there's no mixture adjustment as far as I know, apart from the idle mixture and that's plugged. Edjamacate me! :)
    If it runs fine one week and then goes to chit WITHOUT you touching anything then its most likely a tank of bad petrol or Ignition issue or something wrong with the carbby.
    Is it running rough when you start it or when your crusing at 80/100 or when your WOT?
    Is it running on both cylinders?
    What do the spark plugs look like? Post some PICS!
  • Paulie73
    Paulie73
    Check VOES maybe hose came off.
  • Emperor15
    Emperor15
     Thanks for all the tips guys. I took the plugs out today and they are black with soot. Too rich I'm assuming? Was also told today the carb may be too big for the motor? It's an S&S shorty on a stock Evo motor. Thanks again for the help
    Well the sooted up plugs WILL make it cough and splutter as the spark gets shorted out etc. Replace the plugs and you should be good...BUT that does not address the root cause which by the sounds of things is the carbby settings.
    A S&S Super E should be fine on a stock(ish) Evo (A Super G on the other hand is WAY too much). I would google the jets etc for a Evo and also download the S&S tuning manual from S&S in the USA - its bloody awesome!
  • Emperor15
    Emperor15
     I'll do that mate, thank you.
     hi S&S E is a good carb for the EVO 80 c.i. just set it up proper
  • Emperor15
    Emperor15
    Thank you guys, going to have a good crack at it tomorrow
  • Burnzi
    Burnzi
    I had a similar problem when my bike had original carb on it (87 softail) turned out to be the rubbers on the intake manifold. Having an S&S you probably have a better intake manifold so may be irrelevant.
  • Wimbo
    Wimbo
    Im having exactly the same problem atm with my 84 FXST.
    I'll add some details later if it s ok.
    Ta
  • Wimbo
    Wimbo
    So did you find the problem Emporer?
  • Emperor15
    Emperor15
     Hey mate, still haven't got around to having a good look at it as have been working. Once I do I'll post what the story is.
