Online: beaglebasher, Hilly
Changing wheels and tyres
  • Maxiboy
    Maxiboy
    Hi all,
    I have a Softail Deluxe and I want to put on some new wheels and tyres. So my question is does anyone know;
    1 Will a 21" fit in the standard front fender?
    2 Will an 18" fit in the rear guard?
    3 Can anyone suggest widths for these rims?
    4 Will I be able to buy some sort of White Walls for these sizes?
    5 How will it affect the speedo and can it be adjusted if needed?
    Your help is most appreciated. If anyone has done this to their Deluxe post some photos or tell me what you did.
  • moffycc
    moffycc
    21x3.5  and 18x 4.25  will fit straight on,  as for white wall yes from the US at a cost.  check S.D.M.F 's  posts in here.   good luck they look cool with the big front tyre.    cheers.
