Online: Stuart
Alarm stops bike from starting
  • Aussiehoon
    Aussiehoon
     Got an 09HD FXCWC Rocker Custom had it on trickle charge and went to start it no luck won't even click or turn when try to start . Alarm keeps going off. Whent and bought a new bike battery and still won't start alarm keeps going off. Went and bought new battery s for alarm fobs still no luck alarm goes off. Tried to disarm with manual pin won't do it alarm goes off. Pulling out what little hair I have left. ANY ANSWERS ?????
  • HogBag
    HogBag
    Welcome Aussiehoon
    Does the alarm go of if you move the bike or only when you turn the ignition on. Its posable the tssm is set to transport mode ?.  If the bike is parked around strong electrical curant it can screw up the signal from the FOB.
  • Aussiehoon
    Aussiehoon
     I gave a wind up 240volts power extension which I plug the trickle charger into under the front wheel but this was never an issue in the past ? I will go and take the power extension away to see if this works. The alarm goes off  when I turn the ignition on and won't turn over just nothing.   Thanks for your input tho .
  • scotti
    scotti
    Hey HogBag shouldn`t the transport mode automaticaly deactivate when ignition is next turned on ?
    Mine did this once Aussiehoon and not sure why or if it fixed it but i took the fob out of range then turned the ignition on and off the returned with the fob and tried again , all was ok , strange , are the indicators flashing or anything ?
    Did ya try the manual ?
  • Aussiehoon
    Aussiehoon
    Took the power extension away no good have moved the fobs out of range same no joy. The alarm sound is not as loud as it should be throughout thankfully it seems quieter than normal by a big margin but still goes off with indicators flashing, have tried to manual disarm just sets the alarm off ! Appreciate your help
    Did you buy the right batteries for the fobs? There are a few that look the same, but they have different numbers and they don't work.
  • HogBag
    HogBag
    I would try turning the ignition on and pulling the main maxi fuse then give it a few minutes to reset the ECM and hopefully the tssm . Plug the maxi fuse back in with the ignition on. I will read my diagnostic manual after work and see if I can find a fix. If you send me a PM with your email address I can send you a few pages on how to check the system over and reset the a new sercurity code number
  • HogBag
    HogBag
    Did you check the main battery voltage maybe its fucked and needs replacement
  • Aussiehoon
    Aussiehoon
     Yes purchased a brand new bike battery and fob batteries from HD dealer and still alarm goes off as I said not at full loud noise but quieter maybe the alarm back up battery is stuffed ?
  • russ4570
    russ4570
    Check that the batteries are the correct way up in the fob.    Don't ask how I know.
    Regards
  • Aussiehoon
    Aussiehoon
     Amazing !!!!!!!! Bike now works .  Turns out the new fob batteries I had just purchased were down on voltage  and got them replaced for another new lot and hey presto the bike if fine ......no alarm going off and starts first time.  Thanks a heap to all people for their input and answers very much appreciated.
  • russ4570
    russ4570
    aaahhhh the old dead new batteries trick. Never saw that one coming.
  • Retroman
    Fucking told you it was the fob(s)
    It was the first thing I suspected.
    Duff "new" batteries , shit who woulda thought it !! If I had come round we woulda tried the new one in my wallet, that woulda fixed it !!
    In hindsight ( always a wonderful thing !) I have seen duff new batteries before in my years of experience...
    I will call tonight mate to de-brief...
