Online: wildchild, Soapbox2627
Install 11" rear shocks on my iron
  • JOHNO23
    JOHNO23
     I am need of some advise please....
    I am looking to purchase some 11 inch rear shocks for my iron to give it a lower look.
    I have been quoted a price of $351 incl delivery.
    I am keen to have a go at installing these myself...has anyone done this before and is it a straight forward process?
    it looks as though it may be quite easy, happy to give it a shot.
    Any advise would be appreciated.
    thanks
    Johno23
  • TC883
    TC883
     Johno, it's really easy to change them. You just need to support the back of the bike off the ground. You either use a bike lift, or tie downs around the rear fender. I used the tie downs with towels to protect the paint, and it worked easy. If you search this forum you will find a thread with pictures. Cheers, TC
  • Tee_rav_is
    Tee_rav_is
    I did mine myself mate pretty straight forward. You will just need a bike jack if you don't have only. I got one from super cheap auto for about $100.
  • TC883
    TC883
     Update, here is the thread with pics etc.
    www.hdforums.com.au/Default.aspx
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=1&tpage=3&view=Topic&postid=237542
    TC
  • ConR
    ConR
    Burly Slammers can be purchased from MCAS for $239.
    10.5" shock.
  • Deadwood
    Deadwood
    I purchased Burly slammers from the states, in the end they cost me $3K in repairs, not the greatest touring shocks, might as well go ridgid.
  • maachine
    maachine
    As TC said man really easy to install, don't forget the loctite. I used 11" Progressive 412's on mine, heavy duty coz I'm a heavy bastard. I like the ride, will sometimes launch when hitting a rough patch but all in all pretty good for the price, think I paid about $240 inc post from US.
  • JOHNO23
    JOHNO23
     That is a great result...
    thanks for the advice fellas,
    i am going to give this a shot on the weekend.....I have been thinking about lowering the bike or sometime now and need to make the change now that I am better informed.
    i have a jack I can modify OR I can try the tie own and towel padding you mentioned TC.
    once again, it is great to have the opportunity to grab fast, accurate advice from a forum like this.
    hey Deadwood, noted about the added cost in repairs.....I will keep that in mind....I never thought rigid would be an ideal solution....is that really a good way to go?
    Thanks again
    ( hey TC.....have you had any other mods done to your bike since we last had contact)?
    I sell 11" Shocks to suit Sportster at VPW, $189.00 a Pair
  • JOHNO23
    JOHNO23
     Will do
    thanks TC,
    i have organised to have a look at some option at a local dealer tomorrow. If the price is right, I may even get them to put them on as well.
    I am confident that I could do to job, but I will know more tomorrow.
    johno.
  • JOHNO23
    JOHNO23
     Thanks smokeweazel
    will let you know how I go.
    johno.
  • JOHNO23
    JOHNO23
     Good option there Walka
    Are they available in black?
    i will jump on the VPW website and check them out
  • kevlad
    kevlad
    I Have some 11s brand un known
  • kevlad
    kevlad
    i did mine with a floor jack and a rope over the rafter in the shed
  • skirtster
    skirtster
    Check tension on drive-belt after you lower it.
  • JOHNO23
    JOHNO23
     Thanks for the aadvice
    I appreciate it
