Online: speedzter
Wrinkle Paint
    I've had some success with VHT.  It can be fiddly though, you need to have it not too thick, not too thin, just right !!
    www.speco.com.au/vht_special.html
  • nhb006
    nhb006
    VHT matches streetbob parts perfectly. Warm the parts up, paint and then bake in the oven as per instruction on tge can. You cant go wrong.
    Yeah...that VHT Wrinkle is bloody awesome. have used it on the centre console on my FXR and its perfect.
  • Outlaw01
    Outlaw01
    Harley do the wrinkle paint as a genuine part it will cost you round $25 dollars a can
  • jon doe
    jon doe
    ive used VHT too works well but on the pther hand have you asked your HD dealer they sell presure pack for all there motors I got 09 street bob motor silver to do my derby cover and my points cover .. J.D.
