HD premium oil cooler?
  • berms
    berms
     G'day
    Getting ready to make a deal on a new FXDB this week. Just wondering if it's worth fitting an oil cooler?. Do they really help keep oil temps down? Or only work if you live / ride in extremely hot conditions?
    Thanks for any advice
  • V2Evo96
    V2Evo96
    I wouldn't run a 96" and bigger engine without one. See if you can get one thrown in or bargain for it in the deal. Can get them from the afternarket as well.
  • Retroman
    Berms mate , I have the factory oil cooler on my 2008 Softail, as mentioned already I bought it ex-US when you could do that.
    Works well here in warm WA
    I have just "discovered" the older "slip-on" oil filter cooler/covers , and on another thread I've stated that they work just as well as my plumbed in kit.
    And at a FRACTION of the cost , unless you're getting it "in the deal".
     http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=37&postid=476196&view=topic
    Knowing what I know now I would use the slip-on cooller/collar and not bother with the "Premium Kit"
  • Retroman
    Yes mate, HD used to sell the slip-on coolers in their own branded boxes.
    Then they dropped it from their parts line and introduced the "Premium kit". Remember the 2007 and up bikes run way hotter than the 2006 and older !!
    It's the original producer of the slip-on cooler who now sells them on ebay , good guy to deal with
    Now the premium kit works well as intended, but it's a palaver to fit compared to the slip-over jobbie .
  • jon doe
    jon doe
    im fitting a koler to my 09 street bob a plumbed one it runs hot with a 96 now even more with a 103 ,, just make sure it has a themostat
  • jon doe
    jon doe
    fitted one    to my street bob . mine dont look pritty but gets hot so must be cooling a bit .. J.D.
  • 06 Softail
    06 Softail
    Somebody posted a YouTube clip of this guy demonstrating how tough one of those under frame coolers. Any one know the ones I am referring to? If you do know, what is the price comparison for one of these, and the different types you see advertised on fleebay?
  • Bagger Bob
    Bagger Bob
    Mate its a bud oil cooler , cost around $690 USA . drops temp by 28 deg ruffly .
    They shot at it with a shotgun , can jack the bike up on it .
  • retiresoon
    retiresoon
    the steel cover fell off mine , a poor design,on the vertical one anyway
