Online: speedzter
Repco bike lift Mod
  • chopa
    chopa
    Just modified my bike lift to suit my Dyna
    You need to remove the original lift frame
    You need 2 bits of 38mm x 25mm steel 370mm long. drill the first hole 60mm in from the end and about 13mm up from the bottom then drill your other hole at the same centres as the original frame. I then cut the original rubber strip and drilled holes in the steel to fit it. mount the 2 bits on the outside with the end with the hole 70mm in at the front
  • stilllooking72
    stilllooking72
    Why did you need to modify your lift ? My Dyna fits ok, I just had to put a small spacer on the left hand front side of one of the supports, to help clear the transmission pan.
  • moffycc
    moffycc
     my mod some time ago to suit my bagger.
  • moffycc
    moffycc
    looks good chopa i'd be a bit worried about the bolts taking all the weight though and not the frame.
  • chopa
    chopa
    reason I done this is it's easier than using spacers.
    Bolts will be replaced with h/tensile. This was done in a rush to see if it worked ok using what I had in the shed. Would take alot to sheer the bolts anyway.
  • Deadwood
    Deadwood
    Fuckin good idea, will have to something similar as mine is lowered I can't really use the lifting blocks.
  • moffycc
    moffycc
        One i prepaired earlier used on my softy and yes wobbly ,didn't even try it on my RK.
  • chopa
    chopa
    If you welded a larger square plate on the bottom it would be steadier maybe
  • moffycc
    moffycc
    yeh mate your rite wouldv'e helped , It will stay on the shelf now its done its job.
  • Jimmy The Human
    Jimmy The Human
    thats good shit Chopa. it's given me a bit of food for thought, being the miserable prick I am I picked up a lift from Supercheap, on special for $$99 . and it fits under and lifts my Softail no worrys,,,but it does not seem to steady up there,especially to go hanging of spanners in a big way...(you no giving something a bit of muscle),,to spread the lift arms as you have done might just settle it down that little bit..plus,,,but maybe not,,,be able to get behind the shockies and spread far enough forward to pick up closer to the front of the under frame???mmmm could need some welding here?
    cheers Jimmy.
  • Soapbox2627
    Soapbox2627
    Drag up an old thread but
    the Repco bike lift as pictured above, (prior to mods) are on sale for $118 in their catalogue
    Mod for lifter is for Dyna to clear the sump .
  • 06 Softail
    06 Softail
     Cheers Tim.
  • AJ56
    AJ56
    I have the Repco one. For the money it is worth the money. I have to do some running repairs when I first got it, Chinese manufacturing. But since then no problems. I have heard of the hydraulic jack shitting itself... They were swapped out for a new jack... I think they have a 12 month warranty with them as well. I haven't seen the SCA one as yet.
    Just ahd a look at the SCA lift.  Get the Repco one... The SCA is very similar and probably made in the safe factory.. Both Chinese made so save yourself some bucks...
  • 06 Softail
    06 Softail
    I've just uploaded a pic of the SCA brand lift, check my original post.
  • BillS
    BillS
    I'm guessing this video is about the Super Cheaper lift as it's looks slightly different to the Repco one. It has a couple of neat features like screw down bolts to stop it moving and a safety latch in case the hydraulics shit themselves. Looks OK
    http://www.youtube.com/watch?v=SM-fdO3NL1c
    The Repco one has a lever you push up so if (for whatever reason) the lift fails it only drops a little bit. You just push the lever down when you're lowering it, unless you want to lower it in stages.
  • Colstah
    Colstah
    The Repco one does exactly the same thing (the safety latch), just in a different way. In fact, I'd say the repco one is better.
    I jack the bike up with the hydraulics, engage the latch at the desired height, then release the hydraulic pressure to let the jack rest on the latches, rather that relying on the hydraulics to hold it up. I usually pump the hydraulics up to just put pressure on the lift, as a back-up.
    The screw down bolts are a good idea though. Wish the Repco one had that rather than the wheel locks.
  • steelo
    steelo
    Hi folks. Seen a few threads on folk looking for a bike stand. Bought a Tradequip 650kg ATV, motorbike stand from Burson auto parts. Bit pricier than I'd hoped at $208. Seen later online around $170.
    A snap to put together, seems good quality, low, reasonable pumped up height, quite stable nice wide rubber lined bed to hold bike which had some clearance each side of frame, nice welding, pump looks reasonable quality. Lifted bike easily, 3 step safety, and let it down gently with minimal handling and made cleaning the softtail a breeze today. Didn't really want to push the bike around on the jack. Some pics in case you've been looking.
  • markwoumla
    markwoumla
    I have the same lift.  Had it about 3 - 4  years.  No complaints  !!!   Think i paid about $170 - 190 .   Cheers
