Tmax longterm
Tmax longterm
Hoodaman
Does that thing self adjust mate?
GREG
I've just clocked up 11000km with the t/max and couldn't be happier. The bike runs strong, and cool. I'm stoked with it.
slyde1
There are alot of areas to tweak on the T/Max, timing, AFR's. And now that you have it running so well you should be able to see if changes you make are good or bad. I would save everything you've done before you start tweaking tho, just to be safe.
The A/T, the way I understand it, doesn't over-ride anything you adjust. I adjusts TO whatever changes you've made. So if you lean your AFR at cruise TPS and RPM for better fuel economy, the A/T will adjust to maintain that new target you set.
Brian
