Online: obisteve, speedzter, Wanderer57
Torx bits
  • night train 08
    night train 08
     Hello All.
    Easy question, what size torx bit set to buy for a 08 Harley, assume I need male and female.
    Cheers.
  • Burnzi
    Burnzi
     Black ones are crap and I have bent a few as you can see. Size is from T10 through to T60.
    By the way thats not rust on my tools ..............I like the patina look
  • night train 08
    night train 08
     Cheers for that. Mm Alcohol.
  • MUZZ101
    MUZZ101
    Repco do a good set.
  • MUZZ101
    MUZZ101
    Repco have a lifetime warranty don't they?
  • mick44
    mick44
     With ya female torx, [ E torx ] also buy a 3/8 drive, AF multihex set, E torx and AF multi hex are not the same, ie banjo bolts  on calipers are multihex which is an AF 12 point socket.
    Some sockets sets smaller sockets have six flat sides in socket. AFsix point flat sided socket wont fit a same size bolt head that is an AF12 point socket head or multihex as such.
    Dont need a big AF multihex set. just 3/8 drive, 1/4 to 5/8 or so. There about $60 or so for branded stuff.
    Look at brake banjo bolt and a six sided bolt head, youll see what I mean
    My sidchrome 3/8 AF set is multihex as standard but the Sidchrome 1/4 AF set is six point, which means I had to go and buy another 1/4 AF 12 point set from SP tools.
    hope this helps
