Online: wildchild, Merv
Tyre Valve problems!
  • Crazy Erny
    Crazy Erny
    Okay guys, here is one for the record books! When I took possesion of my 2009 Flstc import  last Feb, I took it to the grunt factory at Yatala for a full service, including getting the air pressure in the tyres checked! The other day before going for a ride I went to check the air pressure & found that the air hose would not fit my valve stem, thinking this is odd I went to three other servos with the same results, what gives? I am fucking spewing, because if for some reason I loose air pressure due to a leaking valve or what ever, I am fucked! I should mention this problem with the valves is in both front & rear tyers!
    Edit to add: Just measured it on my verniers, & it reads: Mine is 7.3mm & my sons bike is 6.4mm.
    i would not use servo pumps unless i had too.
    is the valve tube or tubeless? what seems to be problem? I'm thinking it's screwed in more? why not ride down the Grunt Factory ask what they think.
  • rob.williams
    rob.williams
    Mate, buy a approx, $12 right angle adaptor. Suites all rims and tyres. They are easy to use. Most motor cycle dealers/repairers have them.
    I use the flexi hose (usually at safeway servos) and you just thread it from the middle of the wheel, down through the inside of the spokes.
    A lot of servos had the adapters years ago - you just had to ask for them. Since our modern world is being steamlined I'm betting they don't have them anymore. I'd try a local bicycle shop, then ebay.
    If you end up changing your valves, one of the options you have is to install a angled valve, makes inflating a breeze.
     i've done it for years you just bend there gauge steel line  just before the end fitting  . stick it under  your boot & lever it up put's a nice curve in the steel tube so you can get it in there then it's right for the next rider, easy
