Fat Bob air cleaner options
  • superroo
    superroo
     Hi All, Ive searched a lot of forums for info on air cleaners and havent found exactly what Im after.
    What I'd like to know is this...I have a stage 1 SE air cleaner on my 2012 fatbob.
    Ive recently had a S&S 106 kit installed with reworked heads, 640 cams and V&H pro pipe
    Q, Is there a better air cleaner out there that will add anything more than the SE that I currently have?
    Thanks
  • Glaz
    Glaz
    mate the SE heavy breather is the best by far.
  • robots
    robots
     hi,
    many reckon the SE heavy breather is the up there with the biggest bang for buck mod you can make
    is that peoples experience? I have stock air cleaner but the SE heavy breather keeps catching my eye when I go to the harley shop
    thanks
    robots
  • fastapastor
    fastapastor
    So did you go with the 58 mm throttle body when you did your upgrade? If you did then your limited to your choice of the S&S or SE.
  • superroo
    superroo
    HI Fasta..still has the std throttle body on
  • Ando
    Ando
    Look at the HPI 55 TB or the SE 58mm TB and give that 640cam more air and fuel
    look at the R&R AIR CLEANERS
  • Ando
    Ando
    it ain't the TB its the injector size
  • superroo
    superroo
    Im not looking to do any extra mods to the motor but wondering if an S&S or roland sands etc will be any better than the stage one SE cleaner (not heavy breather). Thanks
  • carbon fibre
    carbon fibre
    Exotx make a good airleaner
    but then so do R&R, S&S, Bob Woods,HPI and a squillion others.
    For ease of availabilty and fitment the Heavy Breather would flow more than your 106 would ever require.
  • fastapastor
    fastapastor
    http://www.sscycle.com/feature/featureview.php?s_id=44
    Look this up. Exy but worth it.
  • superroo
    superroo
    Finally decided on Performance machine supergas. Installed in 30 min by myself and a helpful mate but made the bike splutter and fart. Down to my engine man and hooked up to the laptop. 10min later riding away with a free breathing great looking cleaner. Im a happy man
  • superroo
    superroo
  • Preacher Dan
    Preacher Dan
    Wow!
    Looks great mate!!
    Your bike looks heaps like my mate's bike.... Uncanny! ;)
  • ozymax
    ozymax
    looks good mate, whats with the GTS FATBOB
  • superroo
    superroo
     just some personalisation based on my name....
  • Marvin
    Marvin
     Looks great, have been looking at the same one for my st slim.  Did you buy in oz or from the states?
  • superroo
    superroo
    Hi Marvin, got it from Rollies in QLD...they were a bit more expensive but had it in 2 days
  • ozymax
    ozymax
    Superroo where did you get the S&S kit from? and is it with heads also.
    Just starting to look into this size set up maybe S&S or Fuelmoto or the like.
  • superroo
    superroo
    Hey ozy
    Got it at P&L performance in toongabbie sydney.
    I wanted to keep the build below $4k. Kept standard heads but they were machined....a mate and I weighed up stage 4 but anyone other than harley recommended the S&S 106 for the $$ and it was then just a matter of what cams..one guy said 585's and the guy we went with said 640's based on what we wanted the bikes to do. I love the deep lumpy sound I get with the V&H propipe and its got downlow grunt in every gear....bit of popping on decel but he said that the pipes and cant do much about it. My mate has straight through pipes which dont have any popping.. Im really happy..will do a dyno in the future to see the numbers.
  • ozymax
    ozymax
    cheers mate be interested to see the outcome.
    there seems to be a few good kits around but also some good results from guys that have pieced it together themselves.
    Fuel Moto 107" kit, TW-777 cams, FM Level Be heads, Jackpot 2/1/2, Jackpot Pro Touring mufflers, has a dyno sheet showing 118hp 126ftlb and a very flat torque curve
    wouldn't mind an outcome like that
