Online: Stuart
Seat fitting
  • 4rcruza
    4rcruza
     Hi,
    I need some knowledgable information. I want to change the seat (s) on my 92 FXDC. The seat I have in mind is from a 98 FXWG & sissy bar (extra padding).
    Does any one know if this can be done? or how much modifications will be involved on the rear tab? Thanks for any information offered.
     90's evo's  dyna's did not change i don't think
  • 4rcruza
    4rcruza
    Thanks daddyracer56,
    I have done more research on my sitting issue & my choices are 90 - 95 dyna's seats will only do the job (direct fit) according to the US custom forum & aftermarket products mob.
    Unless I wish to start do modifications, which = more $$$
  • 4rcruza
    4rcruza
    Thanks kiwidave.
    I would probably go a stainless tab, I have a pretty good tool kit to do the job so there is no issues there.
    I just didn't want to go spending hundreds of $ to find it was a waste of time or unforeseen difficulties, as I also want to add a detachable sissy bar to keep the handbrake happy.
    She won't be on the bike very often, but its to keep me in the good books.
    Thanks for the input, cheers.
