Online: Stuart
Oil Coolers
  • sHr3d
    sHr3d
     Hey guys,
    Does anyone run an oil cooler or are we all happy with what we achieve out of tuners making the fuel mix richer therefore cooler?
    I took a look at this one out of interest as I like where he has it placed ie out of sight.
    http://harleyoilcoolers.com/oilcoolerharleydavidson.html#heat
    Wayne
  • kend
    kend
    Yep  i run an after market one on the down tubes and a  k +p oil filter cooler
  • Captain Hook
    Captain Hook
    Bought a harley kit with a thermostat on ebay USA. Works very well, not seen it go over 180 degrees. Oil pressure comes up quick without having to fill the cooler, motor warms up and then thermostat opens so cooler starts working only when oil is hot. It bolts on as an adapter under the oil filter and the cooler mounts on the frame. Very happy with it in hot summers in Perth.
  • ozymax
    ozymax
    got one fitted before i took delivery of the bike
  • sHr3d
    sHr3d
     Thanks guys, appreciate the feedback
    Wayne
  • rob.williams
    rob.williams
    I Have always put on an oil cooler, can't see why HD don't have them standard on bikes comming to Aus. [ across all the range] my new road king has one on as standard].
