forward controls on 2011 streetbob
  • carl65
    carl65
    hi all
    im fitting forward controls to my streetbob went to dealer bought genuine HD controls problem is they only supply 1 plug for the primary cover guessing you need 2 dealer says have to order in (me think not ) does anyone have any ideas on where to buy plugs that may fit
    im in melbourne
    cheers carl
  • carl65
    carl65
    thanks all the welch plug sounds the way to go
  • jon doe
    jon doe
    im putting on forwards too but wanna leave my mids on to for town and hard riding ..J.D.
    Its a dry hole anyway isn't it? No oil can get in there because its just like a tunnel for the shift lever - so the plug would just make it pretty?
    Go back to th damn dealer and tell him to get his chit together! I bet the kit was not cheap, so I would be pissed if it came up short on parts.
