Online: Merv
Rogue scavenger for late model dyna.
  • Spinner
    Spinner
    Anyone know if you can buy a rogue oil scavenger kit  for a late model dyna here in Australia.
  • mickle
    mickle
    got mine direct,dont think you can get them here.
    $69.95 + $20 postage.
  • HogBag
    HogBag
    There was a post a few year back on how to make one with a old oil filter. Maybe someone saved it and can open the old thread again.
  • Spinner
    Spinner
    If you can make up a fitting that fits into the motor for the drain hose and i have a reuseable gauze oil filter element fitted to the bike would it be ok to leave this filter on while the oil is flushed out of the motor and then just remove the filter housing and clean it,    just thinking a loud.
  • AJ56
    AJ56
    There you go.  Home made effort that was posted on here.  I have the rogue choppers one as well and they are worth the money.
    www.hdforums.com.au/Default.aspx
