Online: Merv
  • HogBag
    HogBag
    I just checked my fuel consumpion after Vtuning twice and it came in at 5.2 litres per 100 or 54 mpg. Not bad considering all the engine mods I done to this motor.
  • the_mongrel
    the_mongrel
    That's not bad. I am running a bit less at the moment. I get about 300k out of the tank. Still a few V-Tunes to go yet.
  • HogBag
    HogBag
    My engine is built for torque with CP 103 10.1 stg2 heads 51mm body with a 5-6 wood cam running through a bassani road rage. I took it easy sitting in 5th gear at 110 to 120 kph because of the long weekend holidays with cops and fuck wit drivers everywhere.
  • the_mongrel
    the_mongrel
    HILLY - I am going to try and do a few mor runs this week. If I can get home early enough with enough daylight.
    Question is though... Do I use the map I currently have loaded into the bike and change the tables as per the doc? The map is the one you sent me after you tweaked it?
  • Superglide2012
    Superglide2012
    4.5 litre per 100Km from a Dyna Superglide 2012. I dont fang it around and most trips are a reasonable distance. Not much around town.
    i got a Buell tube frame 1200 sporty motor with a Woods CV carb stepped needle. got 3.8L /100k riding up coffs & back
    my TC95 Dyna uses more but have not worked that out i do about 250k non stop then fill up put about 12 to 13L in but the dyna a quicker bike. ( when its runing still got to fix crank sensor
    Crap...I'm only getting 35mpg. But who the heck cares! Theres a gas station on every corner!
    Yeah okay... Give me a day to sort them as I did a detailed photo shot of the end to end install. I'll post the finished results tonight in a new thread.
  • the_mongrel
    the_mongrel
    Fuck the MPG shit... Just tell us how many Kms you get out of a tank!!
    110 km per tank when running too hard.
  • scotti
    scotti
    Arn`t ya`s worried about tuning them too lean ?
    Most i have got outa me 22.7ltr 6gal roadking tank is 380kms ?
  • the_mongrel
    the_mongrel
    Well, the last tank on my Fat gave me 275km and the light was on, and I was low. Before I did the cams and started V-Tuning I was getting over 300, so more tuning required.
    I agree with you Scotti - I would rather run a bit rich than too lean!!
