Chatter noise after Stage one upgrade
  • Jethro
    Jethro
    Hi fellas,
    I had the stage one upgrade 2012 FXDF ( SE filter and SERT) SE slipons, I nothiced after a day I am getting a chatter / vibration on decel and then it will stay until i get back into the revs. Does the SE airfilter make a noise on decel?
    Anyone else had this?
  • Crusti
    Crusti
    Did you get the right fuel map loaded on the SERT
