Online: GGUser744
Exhaust pipes
  • Gav
    Gav
    18 years ago
    hey Pizzlin
    Ive got a set of big shots sittin here ready to put on my 08 softy as soon as it gets back from the dealers so i cant comment on the fuel injected bikes with them....but i rode a 92 softaiil custom with the same pipes for a few years and really loved them hence buying the same pipes again.. The sound was as good as i had heard without being offensively loud(altho u can still scare the crap outa dogs n old people)lol and as a straight bolt on with no other work when i put them on the bike i gained an extra 6 horses.
    I was pleased with them overall and would highly recommend them. Not as much performance gain as with a 2 into 1 but more than with a standard 2-2 pipe(without any gas exchange)
    Gav
  • deuced
    deuced
    18 years ago
    Hey mate
    I have a set of Big Shot Staggereds with the quiet baffles installed on my 06 injected Deuce. I also fitted a PCIII module and high flow filter at the same time at my local Harley performance shop.
    All up, my HP increased from the standard 60 ponies to just a fraction over 70.
    It's hard to say how much the pipes contributed to the Hp gains cause i did the High flow and PCIII mods on the same day. I did notice how much more responsive the bike was immediately though, felt as though it had been awaken which sounds a bit wanky but it's true.
    I think the quiet baffles were definately worth the extra 150 or so bucks, they  tone the Db's down a bit but also seem to take the raspiness out of the standard BSS note.
    These pipes look awesome in my opinion and i love the real hot rod sound they produce, especially when ripping up through the gears when you twist the wick on a bit!
    As you probably know, you will get better Hp numbers if you fitted a 2 int 1 system to your bike but the Big Shots smack them out of the park in the looks department in my humble opinion!
    Anyway, hope this helps ya mate.
    Deuced
    18 years ago
    Except for the 2-1, the big shots are the pipe being recommended. I went for the short shots. Bit louder. Was told by super cycles yesterday that the baffels made little difference to the loudness so cannot comment there. Frasers put mine on the dyno and I think the hp I got was mid 70's. Not sure how well calibrated their new dyno setup is!!!!
  • Magilla
    Magilla
    18 years ago
    ur such a conservative Mr Fat. Is this how I will end up?
  • snagger
    snagger
    18 years ago
    this is to uncle ho.how much did frasers charge to do that work for ya dyno ect..
    18 years ago
    Sir Garfield.... how much diference did the baffles make? Super Cycles said that don't waste your cash as they make very little diff....
    snagger... PM sent...
