Online: Stuart
Front brake (ABS) pulsation
  • groover
    groover
    Not long purchased a 11 Roadking after having my 08 written off, no thanks to the P plater
    Noticed that when I apply the front brake only I get a pulsation effect through to the handgrip.
    Now I know about the pulsation when you apply the brake hard and the ABS module kicks in to ensure you don't lock the brakes up. But this pulsation is constant even with light application. I can even see the brakes lever pulsating back and forwards as I apply the front brake.
    Ran a dial indicator and micromete rover the front disk with a 0.008" variation in disc thickness with no apparent warpage.
    Is it something I just need to get use too or could there something more to this.
