Online: beaglebasher
12" Apes for 2011 Roadking
  • ozy56
    ozy56
     Im looking fort info on fitting 12" apes to my 2011 Roadking. The bike has drive by wire and ABS and cruise control. I went to my local HD dealer about the parts required and they gave me a list $1000 long. Then there was fitting on top of that. I will do the install myself. Im thinking there would be a kit out there somewhere for this that wouild come in better than that. Does anyone have any info ?
  • mr.gimmick
    mr.gimmick
    yup, that sounds about right....
    i've got for sale a 12" apes bar from Harley, 35" tip-to-tip, 1.25" diam all around, knurled, were fitted on a 2011 road king, nothing wrong with them, all chrome, no marks...
    see this photo below
    $150 plus postage
  • groover
    groover
    Ozy, I've just fitted reach bars to my 11 Roadking (about the forth time I've fitted bars).
    Do em yourself mate, there's nothing more satisfying and you set them up to how you like them.
    I always try and run the wires through the bars which looks better. I'd say you would need longer clutch cable and brake hose with a new set of handgrips. The rest you can do yourself with a soldering iron, heat shrink and some wire.
    You don't need another TBW hand module..!!!!
    Message me if you want any more info, only too happy to help.
    Might write a book on this upgrade I've done it so much.
  • ozy56
    ozy56
     Do you have the cables and brake loines to go with them?
  • ozy56
    ozy56
     The main concern is the ABS. Im told the lines are all 1 piece. I tyhink the HD dealer is adding abit of BS to maintain the confusion.
  • groover
    groover
    Yeah but the ABS cable doesn't run up into the handlebars.
    It goes up behind the headlight then runs down the frame to the ABS module.
  • ozy56
    ozy56
     Hi, Im interested in the bars. can you find out the total cost including postage please. Whats the best way to pay you? DD, paypal??
  • mjp
    mjp
    you can buy cable kits from a lot of places, am just about to try out a burly brand cable kit for a set of 12' going on my dyna. They were the cheapest I had found for a cable kit, without me measuring up and buying everything I needed individually.
    A couple of places can supply those kits, if you want mor einfo ask away, or if in Perth can show you what it looks like :)
    Mal
  • Kustomtown
    Kustomtown
    For a cost saving (I have 16" apes on mine) you can get an extension harness for the DBW also known as FLY BY WIRE.
    If you search Harley fly by wire extension harness, you'll get heaps of hits.
    Good luck.
  • ozy56
    ozy56
     Thanks, Im going to go through Harley. Will put the 16" on instead of the 12"
  • puz
    puz
    hey fellas i'm about to go through this with a pair of 12.5" wild1 apes,does anyone know what length wire & throttle wire extensions i might need ?
  • puz
    puz
    just found handlebar ref chart,should b able to work it out
