Online: Stuart
PowerVision and TTS on same bike?
  • Iolis
    Iolis
    Well i have the power vision with a loaded map to suit my 2012 Dyna FXDB but not running quite right, my option is to takeit and get dynoed for $650 and if i make changes then get re dynoed. In Perth there doesn't seem many people able to work with the powervision like the TTS.
    So i was thinking can i get the new TTS and marry it to my bike along with the Power Vision and get one of the guy's from eher to help me tune it and use the power vision for the screen for checking on the fly rether than log everything. Price for the TTS delivered is $450 so would work out cheaper this way just not sure if the PV and TTS can be used at the same time?
    Any Advice appreciated.
    Iolis
  • ==ShaDoW==
    ==ShaDoW==
    one or the other i believe TTS would still be my choice.
  • KiwiRob
    KiwiRob
    From what I can gather you should be able to tune your bike with Power Vision in a similar way as TTS. - Rob
  • the_mongrel
    the_mongrel
    +1 for the TTS. :)
  • Gonads
    Gonads
    Don't know where in Perth you are but Thundertech in Mundaring seem to be pretty good with the PV from what I have heard.
