Online: GGUser762, Stuart
Swingarm Saddlebag..
  • Spero
    Spero
     I'm looking to buy a left side mounted swingarm saddlebag, I'd prefer the old school type buckles not the plastic quick release ones & aussie made. If anyone can recommend one it'd be much appreciated!
    Cheers, Spero..
  • careyman
    careyman
    u mean the solo bags like the la rosa ones? I was thinking of this too, they easy to attach etc?
  • Spero
    Spero
     So that's what they're called! I checked out the La Rosa website but i'm not a fan, i'm after something simple without all the studs etc..
  • evileye
    evileye
    I've got a Licks solo bag on my Slim. Works well. It has metal buckles for show but locks with plastic clips, still very good though.
  • Wimbo
    Wimbo
    I got a bag made for me by a bird over in Terry Hills (Sydney) that makes saddle bags and saddles for horses
    Looks good and very old School realistic if you know what I mean.
    This type of thing could be another alernative for you.
    Cost about $300.
  • Spero
    Spero
     Cheers Wimbo, has the chick you're talking about got a website or business name?
  • Granox
    Granox
    If you live near the goldcoast I can give you the name of a guy that makes great bags.
  • Wimbo
    Wimbo
    Hi guys.
    Pretty sure it was Terry Hills Saddlery.
    Heres a photo from a distance. I gave her the dimensions I wanted and she made it.
    Shes looped leather Braid or string right around all the perimeters, its a pretty big single bag.
    Obviously collapse in the photo as nothing in it, but I've had it for 5 years or more and ridden through all weather.
    I ride every day so Its copped a canning.
  • Spero
    Spero
    I'm actually looking for a bag that mounts off the swingarm Wimbo, cheers for your info though..
    I'm south of Sydney Granox, do you know f the guy on the Goldcoast has a website??
  • Wimbo
    Wimbo
    Different styles,
    You should be able to design what you want and She'll make it mate.
    Good luck.
  • Roosta
    Roosta
     www.kazzmazz.com.au
    Steve makes all his stuff on site, can mail out. Most if not all in WA use them, best leatherwork around.
