Online: B0nes
ticking from primary?
  • rider
    rider
     Hard to tell where noises come from when riding.
    If primary chain tensioner is stuck you will hear a more irregular noise. Loose chain.
    If compensator nut is loose or compensator is rooted it will be more than ticking and you definitely hear it from primary.
    Ticking is more than likely tappets/valve train noise  or leaking manifold gasket. Hope not a rooted lifter.
  • the_mongrel
    the_mongrel
    Hell yeah. Noises!! Mine always sounds like a swarm of locusts in the engine!! Pwahahahah!
    have you just brought a 1996 EVO w/glide ? or a new 2012  96 c.i. w/glide  just trying to work out the model if it's the 1996 how many klms old
