Online: beaglebasher
Handle bar suggestions for RK
  • Canetoad
    Canetoad
    Hi All
    I am after some input both on changing the handle barsand  I need the bars closer I think.
    I am finding it a lttle difficult once the bike is on full lock as one arm has little control due to being at full reach, without moving my seating position what should I do to bring thestandard  bars a bit closer (I have no idea what is involved) would a different set of bars help, what styles are availavle for the road king, what do you suggest for shorter reach? I am not even sure what I need so any input to put me in the right thinking mode would be appreciated.
  • beagle
    beagle
    HD do have a reduced reach handlebar for road kings. The other option for you is to loosen the clamps and roll the bars back a tiny bit. Sometimes this is all that's needed. Good luck with it.
  • groover
    groover
    Just fitted a set of HD Reduced Reach bars to my Roadking.
    Ran the wires internally for a better finish.
    Made a big difference to comfort and doesn't feel like I'm arching my shoulders/back.
