Online: bikenut57
Cutting Windshields
  • Andysdad
    Andysdad
    Like Quack said - quite easy with a jig saw.
    I used a spare screen as a template for the edge, pencilled the line along the protective tape then cut just outside it so I could sand back to the line.
    Couple of tips - one - the plastic melts as you cut, so make sure the removed part does not stick/weld itself back to the remainder as you cut .
    Two - after finishing the cut, put tape along both sides of the screen before sanding the edge  I used a foam sanding block and didn't notice my hands curling over the top and scratching the see-through face of the screen! Took ages to polish out the scratches......
    A
    Can you download a map for that setup?
  • the_mongrel
    the_mongrel
    I dunno Bonk, but I would advance the cutter 4 degrees to get a nice smooth cut! ;)
  • flacky
    flacky
    I us silicone spray as a lube when cutting perspex with a jigsaw it works great
