Raked Triples
  • o0ben0o
    o0ben0o
    Gday Guys,
    Im considering some raked triples in either 3 or 5 degrees. Leaning more to the 5 degrees. Anyway, ive been told I need 2 inch longer forks for this.
    So if I lower the rear, do I still need longer tubes ? Im gonna go shotgun shocks in the back either way.
    Second part of the idea is im tossing up on goin 23 inch front wheel. Firstly, will a 23x3.5 wheel fit between standard softail standard with trees ?
    And with a 23 inch wheel lifting the front a touch, would that compensate for the need of longer fork tubes ?
    Its all just an idea at the moment but any onfo from the guys in the know would be awesome.
  • gra95770
    gra95770
    Watch your rake and trail, upset that and it gets interesting
  • Spero
    Spero
     I put an Attitude front on my 2011 FXST with a 21" front wheel, it was 3 degrees in the trees & 2" over in the forks. The change in handling was very minimal, it turned in quicker in corners & at walking pace was slightly harder to keep in a straight line. Just to give you an idea of how this set-up is handling wise..
  • Colstah
    Colstah
    Looks like you'd get away with that, but don't take my word for it, I haven't done it, just looked into it once....
    You might want to check out this link http://www.rbracing-rsr.com/advchoppercalc.html
    Again, I have no idea how valid the info there is, but I think it'd be wise to take it into consideration...
  • o0ben0o
    o0ben0o
     Hmm so after doing some calculations with the supplied trail calc page above. If I were to use stock length forks with 3 degree raked triples and a 23 inch fron wheel, I should have a touch better trail than what Spero is currently running. (only by 5mm) adding 2 inch to the forks will take me out another 7mm to 116mm trail.... stock softail standard trail is 147mm while the wide glide is 132mm.
    Sorry... thinking out loud.
  • Spero
    Spero
     Hey Ben, check out my forum topic about my front end conversion, there's some great info in it & also some pics my bike & a couple of others.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=15&postid=383066&view=topic
    Cheers, Spero..
  • the_mongrel
    the_mongrel
    I have the HHI 4 Degree trees with 2 inch overs and love em. They look good, and it handles fine.
  • o0ben0o
    o0ben0o
     Thanks Mongrel. After playing around with that calculator for most of last night, Ive ordered a set of HHI 5 degree triples. Im going to start at standard length as the 23 inch front wheel im going to put on will give me more trail than the 2 inch longer forks would with standard 21 inch front wheel. Then, if Im not happy, I will go for a 2 inch longer set of forks, if it works out well on standard length I will probably go ahead and buy some flash sliders and the progressive monotube inserts as I had originally planned. Id prefer to keep it at standard length as ive ordered the shotgun rear end too so will be running it lowered. The 23 inch wheel with 5 degrees and 2 inch over tubes will put me a touch higher at neck to ground where as standard length puts me a touch lower in the front. Now ive just got to sort out the coin haha. I want to do a heartland ass end too but am tossing up between going to the 250 rear or fitting their EZ200 rear guard and seat over an 18x5.5 rear with a 200.
    Only had the bike a few months. The more I buy the more the addiction grows.....
  • o0ben0o
    o0ben0o
     or... 3 degree trees with 3 degree raked cups for a heap better trail.....hmmm.
  • CACCA
    CACCA
    I got 5 deg and 2 inch over on my softail   and no problems
  • Greek
    Greek
    5 Degrees Rake, 2" Overs -  21" front 18' Rear
  • the_mongrel
    the_mongrel
    Nice! I would have gone 5 for the fatty, but the only offered 4. :(
  • Devo
    Devo
    The bike above looks spot on.
    What would changing the front to a 23 inch do to the ride quality.
  • petermac
    petermac
    Gday im very new to this . Man that is one nice bike, you havnt gone ovr the top you have done a nice job .I,m looking to do the same thing,
    once i,ve sold my current bikes great look
  • Greek
    Greek
    Finally on the road.............howevever waiting for a new front fender from RWD
  • Spero
    Spero
     Greek ya bikes looking awesome! Great job!
  • TJU
    TJU
    Hey Greek great looking job you`ve done there ... am i right in thinking your`s is a 2003 model with that badge ... i have a 2008 softail and am real keen to put one of Attitude`s 18" by 5.5" fat spoke rear wheels in with a 21" by 3.5" front .
    I think i will have to get a another front fender but wanting to know from you good people if there was going to be a drama fitting the 18" under the stock rear gard with the stock wheel being 17" by 6" and will a 200 tyre still fit or should i go back to a 190 or even 180 .
    Cheers guys , any and all info will be much appreciated .
    Tim.
  • Greek
    Greek
    Thanks for that Tim.........cheers
    2003 Anniversary Softail
    Fat Spoke Wheels...........i had a look at those as well, however the Cleaning would have been a nightmare, the original wheels were bad enough FARK
    Original Rim was 16x3.5 with 150 Tire, I'm now running a 18x5.5 Rim with a 200 Tire, few mods required to the Frame, like removal of the original Inner Support Fender Struts, 20mm Rear Pulley with a few Spacers to centre the Wheel in the frame.
    The Rear Fender / Inner Supports and External Fender Struts are 2008, bolted straight on no drama what so ever.
    Trust this assists
    Greek
  • Greek
    Greek
    Cheers Spero M8,
    I managed to clock a few K's over Xmas, however i'm now back in China, freezing my nuts off its currently -10 Degrees FARK
    Huangdao, China
    Thursday
    1/3/2013
    Hi: -6°
    Mostly sunny. Temperature of -6°C. Winds NNW 30km/h. Humidity will be 57% with a dewpoint of -13° and feels-like temperature of -14°C.
    Lo: -13°
    Clear. Temperature of -13°C. Winds NNW 22km/h. Humidity will be 88% with a dewpoint of -14° and feels-like temperature of -20°C.
    Friday
    1/4/2013
    Hi: -5°
    Sunny. Temperature of -5°C. Winds NNW 15km/h. Humidity will be 65% with a dewpoint of -11° and feels-like temperature of -8°C.
    Lo: -13°
    Partly cloudy. Temperature of -13°C. Winds NNW 12km/h. Humidity will be 88% with a dewpoint of -14° and feels-like temperature of -21°C.
  • TJU
    TJU
    Thanks Greek for the info ... i know what you mean about the cleaning but i`ve always been a spoke fan ... give me another reason to spend more money down the line when i get fed up with the detailing , hey it`s only money .
    Geez that weather sounds bloody cold ... i`m presuming you dont get to ride much in China so enjoy your cool ride when you get back .
    Tim .
