Online: B0nes
Going over before first service?
  • ConR
    ConR
     Any issues with it?  I'm at 1600kms, but my shop can't take me for another two weeks!
  • terroristone
    terroristone
    no issue, but i recommend you do oil changes every 3k if your using the HD oil.
    T1
  • ConR
    ConR
    Cool. So like 100 or 200 over is ok?
  • terroristone
    terroristone
    sure is mate. by the time i got mine done i was at 1760k's dont stress, but after that consider changing every 3k regardless of what the book says.
    T1
  • ConR
    ConR
    Sweet. Thx for the info!
  • rider
    rider
    Yeah, cool, sweat as,,,,, just so long as you haven't got any warrenty issues,cause sure as god put tits on sheillas a dealer will baulk at a warrenty claim if the servicing hasn't been done to HD specs. Even if it is just an excuse.
  • the_mongrel
    the_mongrel
    I do mine every 5000k and I reckon that's even too often.
    These engines are pretty simple things, and so is the lubrication. Just my 0.2, but I think 3000k is overkill.
