Online: beaglebasher, Ultramick
chrome switch caps
  • rustom2012
    rustom2012
    hi all,
    i was puting som chrome switch caps on my 2012 road king and managed to crack the horn cap
    can anyone tell me if u can buy these as singles or do i need to buy a hole new pack with all the caps ?
    cheers or if someone has a spare i would like to grap it from them
  • clubbie
    clubbie
    Come as a set from the stealers. Also before you install them it's a good idea to heat them up a little with a hair dryer (careful with a heat gun) to stop them breaking when you put them on.
