Online: GGUser762, Stuart
brake light stays on
  • FXDX01
    FXDX01
    My wifes  XR1200   09    brake light stays on all the time. Only noticed it a couple of days ago and tried the adjustment on the foot brake linkage.....did not work. Cant see any electrical wiring for a switch...? How can I fix this?
  • rider
    rider
    Have ya checked the front brake switch ? common for them to get a bit sticky , worth a look.
  • careyman
    careyman
    contact cleaner spray on switch
  • FXDX01
    FXDX01
    Thanks, the front brake switch seems to work...it moves in and out ok.( light stays on)  Not sure where the rear is fitted to check it out.
  • rider
    rider
    Follow the brake line from master cylinder to caliper, you will find a pressure type switch somewhere on the way.
    Disconnect the wires from it and see if that turns the brake light off, if it does then you'll know that the switch is at fault.
  • FXDX01
    FXDX01
    Yeah rider, I did that and the lights were still on, so it might be the front switch?? I have opened up the switch block and sqirted some contact clean on it  and no change. I also pulled all fuses out and put them back in.No joy!
  • rider
    rider
    Hmmm, well if it's not either of the brake switches playing up and supplying power to the light,,, something else must be.
    My next step would be to pull the fuse for the tail light and see if that puts the stop light off. If so there's a good chance that the tail light and stop light wires are crushed together somewhere,  another easy way  to check, maybe turn the ign on to accessories so the tail light comes on without the ign being on.  If the stop light is getting power from the tail light circuit it will also come on in that situation.
    (just askin,,, has any other work been done to the bike lately ? )
  • FXDX01
    FXDX01
    Yeah rider, a few weeks ago I fitted a harness for a new trickle charger....maybe I did squash/bare some wires?? I'll check it out later this week.
  • the_mongrel
    the_mongrel
    Maybe the "Brake" light is blown, and you are looking at the Tail Light only??
    Since I love asking stupid questions (and sometimes I get it right) it is the brake light lighting up and not the park light? It's the same light just not as bright - which is supposed to be on all the time.
  • FXDX01
    FXDX01
    Well, its fixed!!!  I put in a new globe.... no crushed wires or any damage anywhere, so my wife donated the globe from her 09 Fatbob and ...it worked! Bought the new globe on Wednesday night at the stealers release of the "72" in Adelaide. Thanks for the tips.
