Online: B0nes
will fatbob seat fit road king?
  • Canetoad
    Canetoad
    Hi All,
    Thanks in advance for looking and even more if you have the definitive answer to my question of will a 2010 fatbob seat fit a 2012 road king as someone has a reduced reach seat from a fatbob and I want a RR seat for my road king and I wouldnt mind saving some money into the deal.......  with over 40 odd years of riding I know very little about Harleys because this is my first one and probably last bike purchase.
    Thanks again
    Regards Len
  • scotti
    scotti
    Not 100% but would think the touring frame may be different but you could always try a few to see , i guess where theres a will theres a way ?
    A bit exxy but well worth the money , Mustang is an awesome well made quality product , made to fit your specific model , only risk buying direct being you cannot try the one you want unless you know someone that has one here in Oz , i took the plunge 3 year ago with a big arse Mustang Super Touring seat with rider backrest by memory @ $475+frieght and wouldn`t part with it for quids , it`s a brilliant perch for my FLHRC and looks the goods too , an inch lower than the oem and actually makes it look like a throw away item , quality wise too and i wouldn`t hesitate buying another , I think they are doing discounted frieght as well , as advertised in HD mag ? Check their website out they have cheap to expensive and all different range of styles that fit to perfection .
    There`s a Youtube clip of their factory operations too that`s pretty cool !
  • Canetoad
    Canetoad
    Thanks for your input Scotti. much appreciated.
