Online: Stuart
Cleaning Black Motor
    After a 1500km week-end ride , 300km in wet conditions , bike was filthy with road grime .  Used Inox spray ( CRC WD40 type stuff , but heaps better ) to clean the dirty water stain from motor for a grear result , come up like new .
  • chriso
    chriso
    yep the best shit but expansive
  • terroristone
    terroristone
    i use ct18 in a spray bottle watered down, spray on motor and wheels, wash the rest of the bike then sponge/soft brush the wheels and motor, comes up like new.
    T1
  • ConR
    ConR
    Where do you guys get the s100 from?
  • ConR
    ConR
    Sweet thanks!
  •  GLEN
    GLEN
    CRC 808
  • Ando
    Ando
    cheap degreaser in can from supercheap, hose of and wash, then when dry use tyre shine stuff comes up sweet
  • H
    H
    Yep, inox to clean the motor, wip eoff residue. Then when the motor is dry (and cold), S100 Enginer Brightener. My softail is 16 years old and the black on the engine looks like new.
    I take it this isn't the inox you put into batteries, but some kind of cleaning product of the same brand name?
    Washed off most grime with the hose . Then car wash in a bucket of water and a sponge . Rinse thoroughly with a hose and let dry completely . Then Inox spray the entire motor . I let that dry for a day before I rode it .Smokes a bit when it gets hot ! , but the result is showroom clean .
  • TJU
    TJU
    Hey guys , great thread ... have a mate who just got himself a 2004 SuperGlide with the cast alloy primary cover and has a couple of small oil stains from a previous leak ... will the Ixon get that type of stain out ya reckon or would it be a case of removing and bead blasting .
  • TJU
    TJU
    Thanks Ando , will pass on the info .
    Tim
