Online: Wanderer57
How many Klm per 1.000 revs?
  • Crazy Erny
    Crazy Erny
    Does anybody know how many Kls per 1,000 revs in 6th gear for a 2009 FLSTC?
     Not sure Crazy, i'm guessin at 37-40. i had a heritage i while back now but that was an 04 model so gearing/final drive might differ. try looking at some dyno charts as that will tell ya.
    I'm not much help but now your thinkin at least.
  • Will67
    Will67
     Ok I'm curious , why?
  • Will67
    Will67
     Ok cool, I was told not to worry about using 6thgear unless your doing more than 110 kmh
  • ==ShaDoW==
    ==ShaDoW==
    there is a couple of website that work this out for you, try google if not I will link it when I get home,
    They give you top speed with different tires etc,
    Not sure if it was posted here or on the US forum,
