Online: perthhog
2012 switchback vibes
  • retiresoon
    retiresoon
    At last the annoying vibration which occurs with these models is fixed,Harley have issued a service bulletin to modify front eng mount,funny though my harley shop had not seen it though, Phoenix motorcycles in Warragul Vic did the repair wow its now a different bike to ride (this was done in my 1500 service)
    i found the service bulletin on a american harley forum
    greg
    What is different with the Switchback to the other Dyna,s ? Aren,t they the same family .
  • retiresoon
    retiresoon
    seems to be more of a problem with these models unsure why , might be a bad batch of mounts who knows
  • Stewy
    Stewy
    This is a problem that goes way back. 1998 on
    I have reset heaps of dyna front mounts over the years.
    All different years and models.
    I have not seen a perfect setting out of the factory yet
    First things you do when you buy a dyna is the front mount and the engine -  frame alignment. (front,rear wheel alignment)
    You will be amazed with the difference
    Then you start on the other stuff
