Online: beaglebasher
starting problems
  • Outlaw72
    Outlaw72
    Just wondering if any of you can help.
    Got an 06 Springer, fuel injected. Just fitted some Vance & Hines big radius pipes. Was running fine before, now it wont start. Ignition comes on, turn to "RUN" and sounds like the fuel pump just starts clicking and as soon as you touch the start button I loose all power to the dash and controls. After about 15 minutes or so power comes back when I turn ignition on but the same thing follows,.. last time I tried pump sounded like it was working but hit the start button and instantly lost power again.Thinking it must be somthing simple as I have only changed pipes, can't remember nocking/bumping anything.
    Cheers boys.
  • the_mongrel
    the_mongrel
    Battery?? I wonder if the battery has dropped a cell?
  • Outlaw72
    Outlaw72
    Yep... found a loose wire totally unrelated to the work I just did.
    Just to mess with ya,.. these things happen at the exact moment you work on somthing else.
    Thanks for the input fellas ,.. appreciate it.
    Ride safe boys.
  • the_mongrel
    the_mongrel
    Glad you got it sorted mate. :)
