Online: DIVOT, Hilly
motor
  • sic-puppy
    sic-puppy
     guys, i,m just after some info on a 2006 cvo fatboy....like what size motor do they have & anything i should look for [apart from scammers.... they just dont give up hey]
    thanks
    ian
  • the_mongrel
    the_mongrel
    G'day puppy..
    This might be what you are looking for...
    FLSTFSE2 Screamin' Eagle® Fat Boy® Model Overview
    The Harley-Davidson Custom Vehicle Operations (CVO) crew has infused the new 2006 limited-edition FLSTFSE2 Screamin' Eagle Fat Boy with rowdy performance and a lean, urban custom profile. Based on the popular Harley-Davidson FLSTFI Fat Boy, the Screamin' Eagle Fat Boy features a Screamin' Eagle 103 Stroker Twin Cam engine tuned to crank out more than 100 ft. lbs. of torque, special custom colors with metal grind accents, and a new steel seat.
    Features of the 2006 FLSTFSE2 Screamin' Eagle Fat Boy include:
    Paint:
    Nebula Yellow Pearl and Cobalt Blue
    Autumn Haze and Abyss Blue
    Canyon Copper and Concord Purple
    Frame, frame inserts and swingarm are color-matched
    Screamin' Eagle 103 Stroker Twin Cam powertrain
    New 200 mm rear tire
    New 140 mm front tire
    New 17-inch Road Winder forged aluminum wheels
    New Road Winder billet sprocket
    Road Winder brake rotors
    Buckshot Accessory Collection:
    New grips
    Mirrors
    Rear brake lever
    Shifter lever
    Shifter linkage
    Strut covers
    Derby cover
    Softail chrome front spoiler
    Aileron brake pedal pad and shifter peg pad
    Air cleaner and fuel tank console inserts
    Steel seat with padded insert
    Decorative chrome pillion
    1.25-inch handlebar with internal wires
    Handlebar clamp with tachometer mount
    Chrome handlebar risers
    Chrome fuel tank console and leather extension
    Aileron rider footboard inserts
    Chrome footboard supports
    Slash-down mufflers with chrome heat shields
    Clear-coated, braided, stainless steel control cables
    Chrome wheel spacers
    Stage 1 air cleaner kit
    Teardrop-shaped chrome air cleaner cover
    High-performance clutch with hydraulic actuation
    Chrome voltage regulator
    Chrome headbolt covers
    Silver brake calipers with billet-style chrome inserts
    1.4kW starter (black)
    Chrome clutch line clips
    Spun aluminum metal-faced speedometer and tachometer
    Chrome front axle nut covers
    Chrome swingarm pivot bolt covers
    Chrome smooth-look fork stem covers
    Bullet rear axle adjuster covers
    Smoked turn signal lenses with amber bulbs
    Chrome master cylinder assemblies and switch housings
    Chrome front and rear master cylinder reservoir covers
    Chrome front brake and hydraulic clutch levers
    Chrome license plate bracket
    Stainless switch housing and lever bracket hardware
    Lowered rear suspension
    Chrome lower belt guard
    Chrome sprocket bolt covers
    Chrome valve stem caps
    Chrome tapered tachometer can
    Harley-Davidson security system with siren alarm
    SYN3 synthetic lubricant
    CVO key and CVO storage cover
  • sic-puppy
    sic-puppy
    Mongrel,mate where do you find this stuff,,,ive been looking for days
    ian
    ps, you have a pm
  • the_mongrel
    the_mongrel
    It's called bing plugged into the Matrix 24/7 LOL!!
  • doc58
    doc58
    Hi guys. Sorry to thread mine, but I'm after info relating to the 2006 CVO Fatty also. I understand they come standard with 1 1/4" 'bars, and a handlebar mounted mini tacho (2 5/8" I hope). I have a 2005 FLSTFI, but with late model risers tthat take 1 1/4" 'bars, and I want a "bracket" for a tacho-except I want to put an Autometer boost gauge in it, as I have an intercooled Procharger bolted to my engine. I have not been able to find a mini-tach mount for the 2007 Fatboy anywhere (which my 'bars mimic), but only just discovered that the 2006 CVO Fatboy has just that! Does anybody know if the 2006 CVO tacho mount will fit a 2007 poverty pack Fatboy, and if so, how do I get one? Up to now, my local Harley shop (Fraser's Wollongong) haven't been any help.
    Any help appreciated. Cheers, Mike Wood
