Online: beaglebasher
What to do.
  • 78gold
    78gold
    Ok the game is a foot.
    You have a 2006 Dyna with over 100,000 k's
    Runs fine but you want a bit more stick.
    Would like to do a bit of a "tidy Up" mechanically at the same time.
    88 Cubes - 6 Speed
    K & N High flow air filter
    SE Slip-ons
    Otherwise Stock (Mechanically)
    Stock Wheels - Pirrelli's
    Single and dual seats - Riding two up about 30% of the time.
    Body and accessories wise nothing needed.
    You have a budget of $2500 to $3000 (With maybe a squiggen more if you can convince the minister of finance)
    It is infinately safer not to have to go to the ministry if you can at all help it.
    What do reckon would give you the best bang for your buck. Where would you spend your hard earned.
    Ride Safe All
    Nigel
  • 78gold
    78gold
    Thanks guys,
    This seems a logical approach as to get a big bore kit will throw it over budget.
    Not starting till winter as want to ride through summer and strip it down next winter.
    Ride Safe
    Nigel
