Online: John.R
Progressive fork spring install
  • Crusti
    Crusti
    Hi all
    Posted this under Dynas but got no response
    Installed progressive 11-1525 fork springs in the 2010 FXDWG. Followed their instruction sheet with oil level but found the supplied spacer gave me no preload at all, about 3/4" under the top of fork tube. Progressive tech help suggested using a longer spacer so that it protrudes at least 1/2" above the fork tube giving it 1 1/4" preload. Stock spacer is 4.63", used some pressure PVC tubing cut to 5.85". All seems ok. Anyone got any comments with similar experience?
  • Crusti
    Crusti
    After all this the bike seemed lower than before so I measured the sag. After measuring the fully extended length of the fork and deducting the average difference with me seated on it the sag is 46mm or 1 ¾ inch.
    I have increased the spacer length by another ½ inch so it protrudes 1 inch above the fork tube to achieve a sag of 30 mm or 1 ¼ inch. The spacer is now 6 3/8 inches long.
    Anyone with suspension experience know if this is OK
