Online: Retroman
SORRY GUYS but Needs some advice on cams for my Deluxe 2012, 103ci
  • phsgasit
    phsgasit
      Hi I am confused on which cams to go with ??
    I have a Deluxe 2012 with S&S slip-ons and SE stage 1 upgrade.
    I am looking for torque and hp increases in the 2000 to 5000 RPM range don’t tend to ride above speed limit, more looking for overtaking and 2 up power with sharp throttle performance thru the gears. I am not planning any further engine mods.
    So you guys that have just done your cam please advice on what worked for you?? Could also be talked into V&H stagged big shots??? Instead of the S&S sip-ons but been told going V&H I would lose power…
    So Far my thinking is S&S 583 EASY START ??? or SE 255 but I hear they run very hot in the summer?
  • the_mongrel
    the_mongrel
    I have just installed the new Andrews 57h. According to Andrews they are designed for the RPM range you are speaking of.
    Mine are in a 96Ci but they are listed for 103 too. I can tell you that I am very happy with the bike, and I have only dropped in a base map with my TTS. Once I do some Vtunes, I reckon I am going to be smiling.
    One thing I am really happy with is the idle. I reckon the EFIs idle too "nice" - now... my idle is tops!!
  • phsgasit
    phsgasit
     I am unsure which cams to go with S&S 510 or 583
    could sum one explain why one would be better over the other ?? and which would be the better cam...
    cam
    Valve Timing (open/close)
    Valve Duration
    Valve Lift
    Centerline
    Lift @ TDC
    Intake
    Exhaust
    Intake
    Exhaust
    Intake
    Exhaust
    Intake
    Exhaust
    Open BTDC/Close ABDC
    Open BBDC/Close ATDC
    510
    20°/38°
    52°/20°
    238°
    252°
    .510"
    99°
    106°
    .187"
    .178"
    583
    5°/18°
    58°/24°
    203°
    262°
    .583"
    96.5°
    107°
    .113"
    .206"
