Online: B0nes, WideglidingNZ
Running in new shovel top end
  • johnnybegood.
    johnnybegood.
    Any advice in re to running in a new shovel top end, any tips or advice as there is conflicting advice around in re to this, Thanks.
  • houli
    houli
    Yep,listen to Dave, always good advice when it comes to shovelheads, loud shirts and music not so good
  • Filthy
    Filthy
     If its just a top end as in taking the heads off for a refurb, bolt her up, run a it for a hundred k's or so and retighten the heads and she will be sweet as a nut. No biggie.
    For a rebore/rings etc - see above,
    Philthy
  • johnnybegood.
    johnnybegood.
         Thanks heaps gents, looking forward to my shovel being tip top.
    don't thro too much heat @ her @ 1st , if you let it idle for more than a 1 min put a fan on her  esp around the head's,  after 1st run tighten barrels .heads . rockers etc & check tappets when cold before riding again , do this a few time's in the 1st 500 klms  no big trips  just small stuff let it cool down  inbetween  change the oil in the 1 st 200 klms , use  50/70 W
