Deer/Elk Skin Gloves
  • 883n Harley Convert
    883n Harley Convert
    Anyone ever used something like this? Not sure if they would be any good, but they're cool as I'd be keen to understand whether anyone has used other material style gloves over the traditional leather/mesh style? Gimme a bit of a run down, good in summer, shit in weather etc?
    Waz
  • Underground
    Underground
    Test em out, I'd be keen to have a look at em next time we're out on a ride.
  • Colstah
    Colstah
    I think they are called riggers gloves, those directly above look like they are . Used by roadies, tradies, on the farm, all that kind of stuff.
    I've used them on my bike, they keep the wind out, but for me there is an internal seam (in the web between the little finger and the ring finger) that might get uncomfortable after a while. I've picked them up at hardware stores and electrical wholesalers (I'm a sparky) and at stockman outfitters, like Allingtons. There's not much variation on size, and they benefit from liberal doses of Dubbin to soften and improve water resistance.
  • careyman
    careyman
    yea i use riggers gloves some times. they do have different sizes u can buy too, the seam (it seams) differs slightly on each pair so u might need to try on a few sets if u intend to use for longer rides
    http://www.biancodiamondtools.com.au/custom/files/safety-gloves-rigger-glove-986497.jpg
  • Soapbox2627
    Soapbox2627
    I order XL riggers gloves near every fortnight, by the box
    Small for the ladies, not as often
  • Chimney
    Chimney
    I use deer hide gloves, they're nice and thin so you can get out a smoke and light it, but they are also more abrasion resistant than cow hide so they can afford to be a bit thinner. I've gone down the road in a pair and they didnt wear through, unlike cowhide riggers gloves that did wear through (my only two crashes on the road in over 20 yrs) I believe deer is the second most abrasion resistant to roo hide. The unlined deer hide gloves are the most confortable gloves I've ever used (I've used all different types of leather gloves for work for over 20 yrs too). They're fine in stinking hot and wear them right through southern Vic winter unless I'm punching out big Klm's on a highway, then I have Elk gauntlets with lining. If I'm on the road for hrs and its literally freezing or raining non stop I have some thin waterproof gortex like over gloves but I cant remember when I've last used them. 5 deg and on off downpours and the Elk hide is fine.
    Hope that covers a few basic points
    PS. If you have a problem with stitching aggravating your hands, get outer stitched gloves. Maximum comfort!
    883n Harley Convert
    Will let you once they arrive, but sounding great so far
    Thanks for the feedback gents
  • Soapbox2627
    Soapbox2627
    we had some gloves that consistently had the seam create discomfort, so a new pair of gloves were turned inside out, fixed.
  • Ryno
    Ryno
    Don't know about the colour (just personal) but good luck with trying out your new gloves
    are they very dear,      i have no idea ,    he can't see
    883n Harley Convert
    Happy to report that my gloves arrived, I put the bike sort of back together and went for a strap around my local estate this evening! They're absolutely brilliant, comfortable, fit great and are really lightweight + they look cool haha!!
    Highly recommend gents!!
    These are the guys I bought them from, website looks a little questionable but they arrived quickly and they even sent a thank you card!!
    http://www.bearwallowgloves.com/
    Waz
  • AJ56
    AJ56
    A bit like Platypus Skin Lined Boots
  • Colstah
    Colstah
    Think the guy in this clip has some of those rigger gloves.
    http://www.youtube.com/watch?v=yCYZZPwJr_c&feature=related
