Online: paulybronco
200 rear wheel on street bob?
1/3
  • Ryno
    Ryno
    Anyone got a 200 rear wheel on their street bob? How much did it cost and how much work goes into it? I think it'd look fucken mean!
  • Daggs
    Daggs
    Check the workshop section
  • ConR
    ConR
    Will it take a 180 without a kit? Or did it require work?
  • ConR
    ConR
    Damn it I should have bought a street bob!
  • Ryno
    Ryno
    I know you can get a 'wide tire kit' that makes it fit a 180 but i dunno why they would if it fits in a standard guard. maybe the wide tire kit means you can fit a 200 aswell. I'll have to check that out. wouldnt mind getting the bobtail rear fender too.
  • carbon fibre
    carbon fibre
    I run a pirelli nightdragon 180/55 18 on my 07 Bob, custom wheels fitted, as previously discussed to go to 200 requires work on the indicator wiring/ mounts and the captive nuts for the guards, kits are available to go to 240.
    But by then I reckon you shoulda bought a Rocker. Lol
    saw a 240 at HH in the city a few weeks back... said it cost a packet
    sorry I didnt get a pic of the pivot area.
    He did say it was a awesome ride..
  • Ryno
    Ryno
    That is fucken awesome. sexy as fuck!! I'm gunna have to lok into that!
  • Daggs
    Daggs
    200 fits under the std guard but I recommend you relocate the rear indicators as tyre will rub without doing that.
    Rim also needs to be changed to 5.500" or 6.00"
    Yes as stated 200's can vary. Avon 200 on a 5.500" measured 195 from memory whereas Metz 200 is full 200mm wide.
    These are 18" diameter rims/tyres I'm talking about
    Search for my 200 post if you want more in depth info
    And to finish, beer is good.. Ahhh
  • ezzyd2009
    ezzyd2009
     Hey guys, this is my 1st post. I am in the process of running a 200rear tyre project on my 2013 FXDB. The rim for the back is 18x5.5 to wear an Avon Cobra 200/55 18. I am also changing the front from a 19 to run a custom rim 21x3.25 wearing an Avon 120/70 r21. Watch this space for a completed roject with pics. Am in  Adelaide , SA
  • Stevieboy34
    Stevieboy34
    Looking forward to the updates...
  • ezzyd2009
    ezzyd2009
     the 21 inch wheel is officially on. Pity i could not use the aftermarket Arlen Ness calipers with it as they are a bit too close to the spokes of the 21inch wheel. Here's a pic of the avon tyre on . Rim size is 21 x 3.25 .Tyre is Avon Cobra 120/90 R21. Looks nice and fatt. Stay tuned for thepics of the 200rear soon!!!
  • ezzyd2009
    ezzyd2009
  • ezzyd2009
    ezzyd2009
  • ezzyd2009
    ezzyd2009
     Side view
  • ezzyd2009
    ezzyd2009
     21inch front rim on my 2013 street bob
  • Sparra
    Sparra
    Where did you get the front wheel from???
  • robots
    robots
    Hi,
    Nice one
    Thanks
    Robots
  • ezzyd2009
    ezzyd2009
     Thanx Sparra
    got the wheel custom made by HD wheels in Cali
  • ezzyd2009
    ezzyd2009
    Thanks Robots
    Much better than the 19 inch. Looks beefier . Will let you know how it rides, keep watching this space!!!!
1/3
