Online: B0nes
Subaru upper cylinder cleaner
  • chopa
    chopa
    Anyone ever used this for removing carbon in there bike? I know it works fantastic on a car it's like a tune up in a can and remove carbon deposits from vales, heads and pistons
  • terroristone
    terroristone
    If you are getting that much blow by which causes the problem, then yeah you can use it, oven cleaner is the same stuff!
