Oil Pump Alignment
  • the_mongrel
    the_mongrel
     Hey all,
    So today I started on my Cam install and have been following this video, and some other guides, but there is no mention of Oil Pump Alignmnet.
    http://www.youtube.com/watch?v=n5KvamRqCis
    What am I missing??
  • Ando
    Ando
    Nothing sinister here mate just screw the alignment tool pins in and nip them up as you rotate the engine over ( back wheel and in top gear) then put in the normal bolts and torque up the remove the pins and put the final to bolts in
  • the_mongrel
    the_mongrel
    Hmm! Ok. So why didn't he?  I would have thought he should have done it - or have I missed something?
  • KiwiRob
    KiwiRob
    Some guys use the alignment pins, some just rotate the engine while nipping up 2 of the bolts first to 45in/lbs, then the other 2, then  torque all bolts to spec, which is the way the manual says, & some use the pins & rotate the engine as Ando mentioned.
    Rob
  • the_mongrel
    the_mongrel
    Yeah cool. Thanks guys. He didn't look like he did any of that! LOL!!
