Online: clackavosticus
Exhaust mod for sound testing
  • kookie
    kookie
    Hi all,
    I recently had to put the stock exhaust back on because of the dreaded sound test. Short shots were well and truly over.....
    (this is for my iron 883 by the way)
    The process of swapping back and forth is obviously a pain in @rse....I was wondering if anyone had ever made an attachment that could fit over the end of the short shots for testing purposes.....ok this might sound a of a crazy idea but similar to the short shot slip on's for the stock exhaust I was thinking with a bit of metal work the stock muffler could be used to slip over the end of the short shots (yes and look stupid) to get cleared for the defect ??
    Anyone think this would be possible ?
    Kookie
  • Underground
    Underground
    What about the old Chicken wire trick?
  • kookie
    kookie
    Yeah tried that, even put some steel wool in the mix to further deaden the sound....worked a treat.
    Problem was, first thing they did was stick a hook up into the pipes and pull it out.
  • Will67
    Will67
     what you could try is buy a spare set of baffles i think the V & H come in two types std and quiet.
  • ConR
    ConR
    The quiet baffles will still fail the test, and swapping the pipes as a whole will probably be much easier than swapping the baffles out.  Once they're in there, they're in there!!
  • kookie
    kookie
    yeah I already have the quiet baffles and it still failed by a significant margin !
  • ConR
    ConR
     The Smart Partz Hard Kore baffles are supposed to drop the sound significantly (up to 20%).  That should get it down to the legal limit.
    www.smartpartz.com/SPZVHSHS.html
  • sjn25281
    sjn25281
    I've got the smart parts hard kores in my big radius and it's till the loudest Harley I know. At least 10 db over the limit.
  • ConR
    ConR
    Yeah those Big Radius pipes are loud as shit man! Make the Short Shots look like pussies haha.
