Online: clackavosticus
softail custom risers
  • Ink
    Ink
    Hey fellas,
                        Just a quick query. I am looking to raise my standard bars in height a little.
                        Does anyone know how high you can raise the bars using risers on a 10
                        Softail Custom without having to change the cables etc?  2 inches??
                        Cheers, Ink
  • the_mongrel
    the_mongrel
    If they are the same as most sofies you should get a bit more. I installed 4 inch pull backs and use stock length. I have heard you can go 6 inch - but have not tried.
